Is it possible to use base maps while authorizing via ArcGIS tokens?
807
02-01-2024 03:00 AM
Zamaletto
Hi there!
I'm using IdentityManager to access secured resources (using ArcGIS tokens). There were no issues while I was using portal items like this:
const webMap = new WebMap({
    portalItem: {
But recently I tried to add basemaps and the requests were ending up with 401:
        basemap: {
          style: {
            language: 'nl',
            serviceUrl: `https://basemapstyles-api.arcgis.com/arcgis/rest/services/styles/v2/styles`
If I add that token manually to the URL there are no issues
Is there a way to specify a token when creating a basemap instance? Or make it use IdentityManager anyhow?
The package I'm using is "@arcgis/core": "^4.28.10"
