Is it possible to capture the outline of a polygon drawn using the sketch widget and display it outside of the map?
286
05-25-2020 05:44 PM
TilovonCrite
New Contributor II
I'm using the latest version of the javascript api and I have a use case where an outline of the selected polygon is to be displayed in a popup...not an esri popup tough. thanks.
Tags (1)
RobertScheitlin__GISP
Tilovon,
   Sounds like you want to use the views screenshot capability.
https://developers.arcgis.com/javascript/latest/api-reference/esri-views-MapView.html#takeScreenshot
