Is it possible to : Call Stored procdeure in ArcGIS JSAPI (3.x) ?
1311
10-25-2013 06:00 AM
SunilPalkar
Hello All,
As per the new version is released for ArcGIS JSAPI.
I would like to know whether its possible to Call/execute  Stored procdeure in ArcGIS JSAPI (3.x) ?
I searched a lot on ESRI forum but looks like its not possible still waiting for an miracle : )
If not then ESRI team please explain the reason.
thanks a lot in advance !!!
ManishkumarPatel
Hi Sunil,
Kasa aahes re 🙂
Directly calling a stored procedure using ArcGIS API for JavaScript, it is not possible as of now. Although you can write a webservice to communicate with the database (stored procedures) and get the results as JSON Object.
For reference check this link:
http://www.aspsnippets.com/Articles/Calling-server-side-methods-using-JavaScript-and-JQuery-in-ASP.N...
Hope this helps.
Regards,
Manish
ReneRubalcava
Esri Frequent Contributor
You'd have to expose the stored procedure via your own web service. You could also do it with an SOE or a GP service.
ManishkumarPatel
Hi Sunil,
Kasa aahes re 🙂
Hope this helps.
Regards,
Manish
SunilPalkar
Thanks for your reply.
I want actually call from query layer looks like not possible
OR Something like that my map will be update dynamically.. if I update the stored procedure..
