Is ArcGIS API supports on Mobile (Android)
1007
02-02-2011 11:04 PM
MustafaNoor
i developed some application by using ArcGIS API, will it support on Mobile Platform (Android) ? I mean can i use my application in Android ?
BR
/Mustafa
KellyHutchins
Esri Notable Contributor
Most of the API's functionality should work well on Android. You can test this out by navigating to the help site on your Android device. If you go to http://links.esri.com/javascript from a mobile device you'll see a mobile version of the samples page so you can test the samples out on your device.
