hyperlink in a service  what am i missing???
1156
01-28-2011 11:26 AM
ClintGarrison
Is there a simple way to make the Hyperlinks in an attribute table active in a service? I publish my map as a service, I DON'T make application, because I want to create a simple custom web map. For example the free ESRI sample http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm
Or if I am using Eclipse or Aptana to edit the code. Everything I find is for the Arc Server Applications and not the service.
Clint
KevinBoone
Have you seen this example, which adds hyperlinks to the identify results? Some JS code is required to build the hyperlink (they aren't automatic), but it looks relatively simple.
http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/fl_infowindow....
