IOS 10 user-scalable=no
11265
10-18-2016 08:49 PM
NickCameron2
Since IOS 10  user-scalable=no no longer works in the viewport meta tag.
This obviously breaks maps as pinch zooming zooms the whole page, not just the map.
I couldn't find any workarounds - does anyone have any?
Nick
TonyGeorges1
Hi Nick,
I have the same behavior with Api v4 and iOS 10... After looking at others smart mapping API :-), they use a listener on the documentElement to catch the zoomPinch and double tap events and stop them.
A guy post a similar solution on StackOverflow and you could easily implement it in a dojo module like that :
SO link : http://stackoverflow.com/a/38573198/3366795
Sample dojo module :
 * Created by tony on 28/11/2016.
define([
  "dojo/sniff",
  "dojo/domReady!"
], function (
  sniff
  if (sniff('ios'))
    //Disable pinch zoom on document
    document.documentElement.addEventListener('touchstart', function (event) {
      if (event.touches.length > 1) {
        event.preventDefault();
    }, false);
    //Disable double tap on document
    var lastTouchEnd = 0;
    document.documentElement.addEventListener('touchend', function (event) {
      var now = (new Date()).getTime();
      if (now - lastTouchEnd <= 300) {
      lastTouchEnd = now;
    }, false);
//# sourceURL=vmv/mobileBehaviors.js
Good luck !
TonyGeorges1
Hi Nick,
define([
  "dojo/sniff",
  "dojo/domReady!"
], function (
  sniff
  if (sniff('ios'))
    }, false);
      lastTouchEnd = now;
    }, false);
Good luck !
NickCameron2
Hi Tony,
Thanks heaps for this! I'll give it a try when I get a chance and report back how it goes.
Nick
NickCameron2
Hi Tony,
Just had a chance to try this out and it is working well, thanks again!
I also have an absolutely positioned menu system on top of the map. I added the below to stop the menus from bouncing around when panning the map.
//disable scroll on the map containers so the menu doesn't bounce around when panning the map
 let mapContainers = document.querySelector(".view");
 mapContainers.addEventListener('touchmove', function (event) {
 }, false);‍‍‍‍‍‍‍‍‍‍
