Intersecting with an entire FeatureLayer?
1931
11-09-2023 12:59 PM
NicholasRolstad2
Maybe I'm just not wording my searches correctly, but I can't seem to find an answer to this. Is there a way to run a simple true/false intersect on an entire FeatureLayer?
Essentially I have a single polygon feature and I want to see if it intersects with a different Feature Layer that has 10's of thousands of features. Is the only way to do this to loop over every feature, checking if each one intersects with my target feature or is there a simpler way?
Thanks!
ViktorSafar
queryFeatures with spatial query
https://developers.arcgis.com/javascript/latest/api-reference/esri-rest-support-Query.html
Using the example from the link,
view.on("pointer-move", function(event){
  let query = featureLayer.createQuery(); // THE OTHER LAYER
  query.geometry = YOUR POLYGON
  query.distance = 2;
  query.units = "miles";
  query.spatialRelationship = "intersects";  // this is the default
  query.returnGeometry = true;
  query.outFields = [ "POPULATION" ];
  featureLayerView.queryFeatures(query)
    .then(function(response){
      // returns a feature set with features containing the
      // POPULATION attribute and each feature's geometry
ViktorSafar
  query.distance = 2;
mleahy_cl
If we're only interested in knowing whether any features intersect, and don't need to know details anout the individual intersecting features themselves, we could also consider using the queryFeatureCount() method of a FeatureLayer - any count greater than zero means your polygon intersects, and a count of zero means no intersection.  This saves having to transfer and process geometry and attribute data.   Depending on your use case, that may be beneficial.
