Integrate into ArcGIS Online
2332
03-06-2017 06:44 AM
FriedaL
I have created a relatively simple map with the ESRI javascript API (just a few points based on a geojson) and I currently only have it on my local computer. Now, I was wondering whether there is a way for me to add this web map to ArcGIS Online directly (not as a link to real location but really hosted in ArcGIS online)?
RobertScheitlin__GISP
Frieda,
  No AGOL does not act like a website hosting service.
Frieda,
   If you have an AGOL account then adding the geojson toAGOL and a new webmap is not going to be hard at all.
ArcGIS Online supports GeoJSON | ArcGIS Blog
FriedaL
Thanks Robert, this is correct and easy to do but I'm wondering about something else. What I'd like to do is host an existing app created with the Javascript API  in ArcGIS Online. While, if I understand you correctly, you suggest I create the same map again using ArcGIS Online.
Frieda,
