Inject Angular Component As Popup Content
2368
08-06-2021 09:41 AM
rogenjh
Hey Everyone,
This is a question I've wondered about for a while, so I'll pass it to the community here.
Is it possible to inject an Angular component as ESRI popup content? If so, does someone have an example of this working? I've poked around for a while and haven't found anything specific enough to help me.
Thanks!
AndyGup
Hi @rogenjh, can you explain a bit more about what you want to do?  In general that seems problematic with all the external dependencies and life-cycle hooks that are inherited with an Angular component. It wouldn't be a clean implementation.
rogenjh
Hey Andy,
I'm looking for something like this (what I posted below), but Angular not React. Basically, I'd like to inject a component as the content and be able to access change detection, dependency injection, etc. just like the rest of my application. I've done it (and seen others do it) by writing Vanilla js into a factory function in the content, but I'd think there should be a way of avoiding that if possible.
https://community.esri.com/t5/arcgis-api-for-javascript-questions/create-your-own-react-popup-compon...
AndyGup
I've seen similar implementations and they aren't recommended because it can lead to unintentional memory leaks in the form of detached DOM nodes and other unpredictable Map/MapView life-cycle issues.
