InfoWindowTabContainer error (object error)
1050
03-23-2012 02:42 AM
CliveSwan
I am trying to put the TabContainer into a loop. The aim is to set the size of the TabContainer
function getInfoWinTabContainer() {
    try {
        var tc = dijit.byId("tabs");
        //On IE setContent destroys the dijit
        if(tc === undefined)
             if( (theLayerName != "Underground") && (idResults.length  <= 1) )
  // alert("1 record");
  //map.infoWindow.resize(360, 200);
  tc = new dijit.layout.TabContainer({
  style : "width:354px;height:196px;visibility:hidden;display:none;padding:2px;", id: "tabs"}, dojo.create("div", null, dojo.body()));
   else if ( (theLayerName != "Underground") && (idResults.length  > 1) )
                  // alert("> 1 record");
    // map.infoWindow.resize(900, 425);
            style : "width:890px;height:420px;visibility:hidden;display:none;padding:2px;", id: "tabs"}, dojo.create("div", null, dojo.body()));
       } else {
            tc.domNode.style.display = 'none';
            tc.domNode.style.visibility = 'hidden';
CliveSwan
Tried to create a variable for the TabContainer to use for the TabContainer size.
Getting  getInfoWinTabContainer  error??
getInfoWinTabContainer error, details: [object error]
Code
    try {
var tcSmall = new dijit.layout.TabContainer({
var tcLarge = new dijit.layout.TabContainer({
            style : "width:890px;height:240px;visibility:hidden;display:none;padding:2px;", id: "tabs"}, dojo.create("div", null, dojo.body()));
