InfoWindow
1038
05-16-2012 02:00 AM
KennethHo
Hi, I am new to this.
Erm, I need to create markers to place them on a map. The markers will need text inside it and the design is somewhat similar to InfoWindow.
I have tried using InfoWindow. However, it was not possible for me keep more than one InfoWindow open on a map.
I have also tried using symbols. But the symbols only allowed text or image. I need both of them.
So the question is issit possible for me to open more than one InfoWindow on a map? Or is there any other object that I can use for this purpose? Thanks =D
derekswingley1
The map can only have one infoWindow open at a time. This also applies to the popup but with the popup you can specify multiple features and page through them.
If you're not displaying a lot of text, you might want to use a text symbol and a point (or line or polygon, depending on your data) symbol for each feature.
