InfoWindow zoom issue after upgrade to Server 10.2.2
1058
06-16-2014 06:44 PM
JillianStanford
Ever since upgrading ArcGIS Server to 10.2.2 I've been experiencing some strange behavior from the Zoom To function on the default InfoWindow. When I click Zoom To the map zooms out so far that I can no longer see any other layers or my basemap. All my services, serving a variety of data sources exhibit this behavior. The layers seem to work correctly in every other way.
To rule out issues with my code, I open this sample in a sandbox and swap out a service on my 10.2.2 machine for the parcelsURL variable. I get the funky behavior. I then publish the same dataset on a 10.11 box and the sample works as expected.
When zooming to the same feature, the map based on the 10.2.2 service is zoomed to XMin: -1100124434934.61 YMin: 33623503.45 XMax: -1099873496451.23 YMax: 173729518.82 while the map based on the 10.11 service is zoomed to XMin: -10371573.06 YMin: 4422116.48 XMax: -9391344.61 YMax: 4969405.60.
Any ideas?
Thank you!
Jill
JillianStanford
In case it helps anyone else, this turned out to be the result of a bug in the Identify Operation.
Details and workaround here: http://forums.arcgis.com/threads/106418-ArcGIS-Server-10.22-Identify-Issue
Jill
JillianStanford
Jill
