Infowindow sprite background-image at runtime
2042
06-11-2010 07:08 AM
RaviKonaparthi
Hi All,
I am working on creating an application where i  need to change the background of my infowindow at runtime based on the graphic attributes. I am able to set the infowindow style in the CSS by overriding the .infowindow .sprite. But i am unable to change the sprite at runtime.
Can any one help me solving the issue?
Regards,
Ravi.
RaviKonaparthi
Hi All,
Can any one help me on this?
Regards,
Ravi.
RaviKonaparthi
Hi All,
I tried all the possible ways from my end with no luck. Can any one have solution for this feature?
Regards,
Ravi.
RaviKonaparthi
Finally i found the solution and here it is...
CSS:
.orangeSprite
    background-image: url(images/orangeinfowindow.png) !important;
    _background-image: none !important;
    color: White;
    _filter: progid: DXImageTransform.Microsoft.AlphaImageLoader(enabled='true', sizingMethod='crop', src='images/orangeinfowindow.png') !important;
Code:
Before showing the infowindow, please use the below code:
var infoWindow = map.infoWindow;
var sprite = dojo.query('.sprite', infoWindow.domNode);
for (var i = 0; i < sprite.length; i++) {
       sprite.className = 'sprite orangeSprite'; //sprite is the default class for infowindow and orangeSprite has the actual sprite image to be displayed.
map.infoWindow.resize(380, 220);
Now call the resize() method.
You will get the new sprite image, instead of the default provided.
Regards,
Ravi.
BenStuder
CSS:
.orangeSprite
    color: White;
Code:
Regards,
Ravi.
Clever, Ravi. I will have to try that.
