Infowindow Popup Window Controls
1747
06-18-2011 10:48 AM
ChristopherCouper
How can I control the Window Controls in a popup?  For example I only want the close (X) item and not the maximize item in the window bar?
BrettLord-Castillo
One very simple way to do this is to set the style on the elements you do not want to appear. You can do this by calling esri.hide() on the main containing div element for that element. I'll see if I can find what that call would be for the minimize button.
ChristopherCouper
Thank you in advance. Its actually the maximize button that needs to be hidden 🙂
VernWolfley
You can control this through the CSS -
.esriPopup .titleButton.maximize {
     display: none;
hope that helps
