Infowindow not hiding on infoWindow.hide
2708
05-16-2012 12:33 AM
TurbinJ
I have a problem with my infowindow. It is a Popup window.
When the user selects a button on my Toolbar I call a function and when I debug I can see that the function is called. But it doesn't hide my infowindow. Anyone got an idea about why it is still visible?
Here is a snippet
[HTML]function turnidTool(ident){
  map.infoWindow.hide;
  if (ident==1)
   if (defltHandle==null)
     defltHandle = dojo.connect(map, "onClick", doIdentify);
  else
   dojo.disconnect(defltHandle);
   defltHandle = null;
   resetFunctionality();
  }[/HTML]
derekswingley1
map.infoWindow.hide is a function so you need parentheses after it to call it:
map.infoWindow.hide();
derekswingley1
TurbinJ
Simple enough! Thanks so much för your help 🙂
