infoWindow content not clearing as expected from clusterLayer
7264
12
03-02-2015 12:47 PM
TracySchloss
Honored Contributor
I have a clusterLayer based on the point clustering example:https://developers.arcgis.com/javascript/jssamples/layers_point_clustering.html
Toward the top, I define my infoTemplate and call the function to generate the clusters:
      infoTemplateContent = "<b>Status: ${FlagStatusDescription}</b><br>"
        +"Type: ${ItemFunctionDescription}<br>"
        +"Agency: ${AgencyAcronym}<br>"+
        "Address: ${EntityLocationAddress1}<br>"
        +"City: ${EntityLocationCity}<br>"
        + "IP address: ${II_IPAddress}";
        infoTemplate = new InfoTemplate();
        infoTemplate.setTitle("Server ID: ${Item_Name}");
        infoTemplate.setContent(infoTemplateContent);
        createCluster();
Here's the function
  function createCluster(){
    var queryTask = new QueryTask(pathName+"/ArcGIS/rest/services/myService/MapServer/1");
    var query = new Query();
    query.returnGeometry = true;
    query.where = '1=1';
    query.outFields = ["*"];
    queryTask.on("complete", function(results){
        var inputInfo = {};
        inputInfo.data = arrayUtils.map(results.featureSet.features, function(feature){
          var point = feature.geometry;
          var att = feature.attributes;
          var pointX = feature.geometry.x;
          var pointY = feature.geometry.y;
            return {
                "x": pointX,
                "y": pointY,
                "attributes": att
        var singleServerSymbol =  new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 10,
         new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0,0,0]), 1),new Color([0,205,0,0.25]));
        // cluster layer that uses OpenLayers style clustering
        clusterLayer = new ClusterLayer({
            "data": inputInfo.data,
            "distance": 5,
            "id": "clusterLayer",
            "labelColor": "#fff",
            "labelOffset": 10,
            "resolution": res,
            "singleColor": "#00ca00",
            "singleSym": "singleServerSymbol",
            "singleTemplate": infoTemplate
        var renderer = new ClassBreaksRenderer(singleServerSymbol, "clusterCount");
        var single = new PictureMarkerSymbol("https://static.arcgis.com/images/Symbols/Shapes/GreenCircleLargeB.png", 18, 18);
        var small = new PictureMarkerSymbol("https://static.arcgis.com/images/Symbols/Shapes/GreenPin1LargeB.png", 48, 48).setOffset(0, 15);
        var medium = new PictureMarkerSymbol("https://static.arcgis.com/images/Symbols/Shapes/GreenPin1LargeB.png", 64, 64).setOffset(0, 15);
        var large = new PictureMarkerSymbol("https://static.arcgis.com/images/Symbols/Shapes/GreenPin1LargeB.png", 96, 96).setOffset(0, 15);
        renderer.addBreak(0, 2, single);
        renderer.addBreak(2, 25, small);
        renderer.addBreak(25, 100, medium);
        renderer.addBreak(100, 5001, large);
        clusterLayer.setRenderer(renderer);
        map.addLayer(clusterLayer, 1);
        queryTask.on("error", function(err){
            alert(err.details);
       map.on("key-down", function(e){
            if (e.keyCode == 27) {
                cleanUp();
    queryTask.execute(query);
function cleanUp() {
    map.infoWindow.hide();
    clusterLayer.clearSingles();
I'm noticing that if I first click on a cluster to get information and follow that with the geocoder Widget, the infoContents that popup from my geocoder's showLocation function continues to retain the information from the clusterLayer.  It does start with evt.result.name,but also has the arrow indicating additional content.  When you click the arrow, you see the additional content content is the previously show information from the clusterLayer.
   function showLocation(evt){
       var symbol = new SimpleMarkerSymbol();
       symbol.setStyle(SimpleMarkerSymbol.STYLE_CIRCLE);
       symbol.setColor(new Color([255,128,0,0.75]));
       map.graphics.clear();
       var point = evt.result.feature.geometry;
       var graphic = new Graphic(point, symbol);
       map.graphics.add(graphic);
       map.infoWindow.setContent(evt.result.name);
       map.infoWindow.show(evt.result.feature.geometry);
It seems like the the cleanUp function for the clusterLayer would take care of this.  This project contains sensitive data, so I'm sorry I can't give you a link to the actual project.
Tags (1)
by Anonymous User
Not applicable
Correct. This is just a thought, hope it helps.
TracySchloss
Honored Contributor
Actually, it looks like all I was missing  map.infoWindow.clearFeatures.  First I put in your lines, but then I commented out the setInfoTemplate to see what happened.  It worked w/o that line.
by Anonymous User
Not applicable
Great news! Love when things get fixed
