Infotemplate not working
1622
01-29-2012 05:17 PM
XueLing
My info template is not working at all currently and it looks like this :
var stadium = [];
var symbol = new esri.symbol.PictureMarkerSymbol('/images/icons/stadium.png', 25, 25);
var infoTemplate = new esri.InfoTemplate();
infoTemplate.setTitle("Stadium");
infoTemplate.setContent("This is a stadium.");
var graphic = PointGraphic;
graphic.setSymbol(symbol);
graphic.setInfoTemplate(infoTemplate);
stadium.push(OneMap.map.graphics.add(graphic));
Can anyone help and tell me what's wrong with it because it was working fine 2 months ago.
Thanks and regards,
Xueling.
derekswingley1
What changed?
XueLing
Hi there,
What do you mean by "What changed?" As in what is not working?
2 months ago, its working which means that when I click on the icon on my map, the infoTemplate will pop out with the specific information. But now, when I click on it, nothing appears at all.
Thanks and regards.
derekswingley1
If it used to work, but now doesn't now, something changed. Can you post your code?
XueLing
Hi there,
var stadium = [];
dojo.connect(themeGraphicsLayer, "onClick", function (evt) {
                mashup.GetDataForCallout(evt.graphic, "", function (results) {
                    var formattedResults = formatResults(results);
                    map.infoWindow.setContent(formattedResults);
                    map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
function formatResults(resultObject) {
            var nameVal = ""
            for (var i = 0; i < resultObject.length; i++) {
                nameVal = nameVal + "<br>"
                nameVal += "<strong>" + resultObject["NAME"] + "</strong>" + "<br/>"
                nameVal += resultObject["DESCRIPTION"] + "<br/>"
                nameVal += "<a href=" + resultObject["HYPERLINK"] + " target='_blank'>More Info</a>" + "<br/>"
                if (resultObject["PHOTOURL"] != "") {
                    nameVal += "<img src=" + resultObject["PHOTOURL"] + "></img>" + "<br/>"
                else {
                    nameVal += "<br/>"
                nameVal += resultObject["ADDRESSBLOCKHOUSENUMBER"] + " " + resultObject["ADDRESSSTREETNAME"] + " " + resultObject["ADDRESSBUILDINGNAME"] + " " + resultObject["ADDRESSFLOORNUMBER"] + " " + resultObject["ADDRESSUNITNUMBER"] + "<br/>"
                nameVal += "Singapore " + resultObject["ADDRESSPOSTALCODE"] + "<br/>"
            return nameVal
Thanks and regards.
