Index of ServiceLayers in a Map
1022
11-15-2011 04:14 AM
UrsRichard
Hi there,
I have a map with serveral different MapServiceLayers (DynamicMapServiceLayers and FeatureLayer). Now I'm looking for indexes of each of this services in the map. So I like to know which is the topmost, the second topmost etc..
With the information about the indexes I can as as example the map.reorderLayer(layer, index) function for reordering.
best regards
Urs
SanajyJadhav
You can use LayerInfo object to get the sub layer IDs.
This documentation talks about LayerID proprty of the feature layer
Hope this helps.
HemingZhu
Hi there,
best regards
Urs
All layers has a id property. Even though it is a string type. you could name the layers '0', '1', '2'.... Since javascript is loosely typed, those ids can be easily treated as number with min code.
