I am new to javascript. In windows Visual Studio Code, I want to get arcgis api Intellisense , some guidebook says first install node.js and typings, then install arcgis api.
The typings tool may be used to install this using the command:
typings install --global github:Esri/jsapi-resources/4.x/typescript/arcgis-js-api.d.ts
</CODE></P><P><CODE>execute above line in cmd.exe , error shows the location is bad.
SO how can I install arcgis-js-api.d.ts
Thanks!
