img src in FeatureLayer popupTemplate
1420
03-04-2025 09:10 AM
JohnDMorgan
Hello,
I am trying to point to an img src that is a string/path on a FeatureLayer, but it always comes through as a broken image. Can anyone point me to how to get this to work? I think I must bypass the popup template class or something to this effect. Here is my code snippet:
const featureLayer = new FeatureLayer({
url: "https://services.arcgis.com/eoP5lsTDzcIUyaQZ/arcgis/rest/services/.../FeatureServer",
popupTemplate: {
title: "{Name}", // Field from the feature attributes
content: `
<b>Image Path:</b> {ImagePath}<br>
<a href="{ImagePath}" target="_blank">URL</a>
<img src="{ImagePath}">
JohnDMorgan
JohnDMorgan
This is the result I get:
JohnDMorgan
LaurenBoyd
Hi @JohnDMorgan -
In case you haven't gotten this working yet, you can use a function to format the popup content and that should get links working for you. You'll just need to pass the feature into the function so that you can access the attribute that contains the image src path.
Check out this example: https://codepen.io/laurenb14/pen/zYJqzYp
Hope this helps!
Lauren
