Image media not displaying in arcgis-popup component v5.0.9
1086
03-05-2026 07:47 PM
Michael_Fletcher
Using ArcGIS Maps SDK for JavaScript 5.0.9 arcgis-popup component
Popup configured in AGOL webmap displaying image media from publicly accessible url.
The image url contains braces { } anything between these including the braces is being removed from the url.
Resulting in an empty div with dimensions displaying in the popup.
This doesn't occur when using the now deprecated "@ArcGIS/core/widgets/Popup.js"
The quick solution is to remove braces from the image filenames, however thought I'd mention this here, it appears to be a bug.
LaurenBoyd
Hi @Michael_Fletcher -
We have fixed this issue in the next release of the JS Maps SDK (version 5.1) which will be released mid June. You could test the fix with the 5.1.0-next version of the SDK: https://github.com/Esri/feedback-js-api-next
Thank you for reporting this issue!
Lauren
GianlucaMiele1
Thank you for reporting this, @Michael_Fletcher. We have opened an issue on our side and will investigate and resolve it shortly.
Would you mind sharing the public webmap with us, if possible?
Thanks, Gianluca
Gianluca Miele | Principal Product Engineer Web 3D
Esri
Michael_Fletcher
LaurenBoyd
We have been investigating with our own data in house and this seems to have not worked for neither the Popup widget nor the Popup component in previous releases in our test case. For us to investigate further, could you please provide us with the public web map?
Lauren
LaurenBoyd
Update to my comment earlier, I believe we have been able to reproduce the behavior you're experiencing. We are currently investigating. Thanks for reporting this!
Lauren
LaurenBoyd
Lauren
