IE sometime doesn't show the graphic
1215
07-06-2010 11:18 PM
HeiJo
I make a QueryTask application. It queries for polygons and return geometry. I let the graphic result show on the map. In FF it works perfectly. But in IE some big polygons not showed.
How can I fix this issue. Thanks!
AdamPfister
i think we'll need a bit more explanation and a code sample to have any idea what you're doing.
justinperez
I have similar issue (and posted it but I can't find it now).  I have one of the samples from the jsapi 2.0 and put in my map service endpoint polyline dataset.  This works fine for one of my endpoints, but then I put in a different more busy and larger polyline and the data doesn't draw completely in FF and stalls IE8 out completely.  Thanks.
the sample I use with slight modifiaction --> http://help.arcgis.com/en/webapi/javascript/arcgis/demos/query/query_hover.html
Attached is my htm page.
