IE 11 works fine within VS 2010 but alone doesn't
3760
09-03-2014 11:28 AM
JoseSanchez
Hi all,
I am running a web ADF application in IE 11 and this is the issue I am having:
When I run the "Zoom In" with VS 2010 that open IE 11 it draw a non-transparent box in the screen and it zooms to it. It draws a rectangle and the cursor is located at the bottom right. This works fine.
When I open the same page directly for IE 11, When doing a  Zoom In, it draws the rectangle and the cursor is at the upper left of the rectangle. This is not correct.
Any ideas in how to fix that?
EhabEl-Masry
u will need to try the browser debugging tool to know exactly what errors taking place in the run-time..
