IdentifyTask Error - "'imageDisplay' parameter is invalid"
1620
07-11-2012 02:05 AM
TiagoRibeiro
Hello everybody!
I've encountered a slight problem using the IdentifyTask. When I execute it it returns the following error:
code: 400
details: Array[1]
    0: "'imageDisplay' parameter is invalid"
What is imageDisplay? I haven't encountered that parameter anywhere in the API reference (Maybe I missed it?)
Can anyone give me a hint?
ChristophSpoerri
hi there,
In case you didn't solve the problem yet. The solution is, that you also have to set the height and width of the IdentifyParameters.
Cheers,
Chris
ChristophSpoerri
hi there,
Cheers,
Chris
TiagoRibeiro
hi there,
Cheers,
Chris
Hi Chris,
Thank you for your response.
I don't remember what I did, but I resolved the issue. Maybe with what you said. 🙂
Tiago
