Identifying a featureCollection based FeatureLayer
2168
11-07-2013 03:09 PM
danbonab
I was having trouble identifying a FeatureLayer taht was created from a featureCollection. I was getting the error "query has one or multiple unsupported parameters". I debugged a little further and noticed in FeatureLayer.js there is a line of code that requires the geometry type for queryFeatures be of type "extent" and since my geometry type was "polygon" it was throwing the error.
_canDoClientSideQuery: function(a) {
            var c = [], b = this._map;
            if (!this._isTable && b && !a.text && !(a.where && a.where !== this.getDefinitionExpression() || a.orderByFields && a.orderByFields.length)) {
                var d = this._isSnapshot, e = this._isSelOnly, f = a.geometry;
                if (f)
                    if (!e && a.spatialRelationship === K.SPATIAL_REL_INTERSECTS && "extent" === f.type && (d || b.extent.contains(f)))
                        c.push(1);
                    else
                        return;
                if (b = a.objectIds)
                    if (d)
                        c.push(2);
                    else {
                        var f = b.length, l = this._mode,
                        g = 0, m;
                        for (m = 0; m < f; m++)
                            l._getFeature(b) && g++;
                        if (g === f)
                            c.push(2);
                        else
                            return
                if (this.timeInfo)
                    if (a = a.timeExtent, b = this._mapTimeExtent, d)
                        a && c.push(3);
                    else if (e) {
                        if (a)
                            return
                    } else if (b)
                        if (-1 !== h.indexOf(c, 2))
                            a && c.push(3);
                        else
                            return;
                    else if (0 < c.length)
                        a && c.push(3);
                    else if (a)
                        return;
                return 0 < c.length ? c : null
Why is that? why can I not pass a polygon? Any explanation would be extremely appreciated.
Cheers
