Identify Task
2532
04-20-2016 11:00 AM
Hernando_CountyProperty_Apprai
Is there any way to change the standard "No information found" message when doing an identify task that returns no results?  Any help would be appreciated.
SteveCole
Honored Contributor
It might be. I would look into this page of the API documentation where it talks about changing the default text used for API items such as buttons, tooltips, etc. There might be a property related to the identify task.
Actually, this thread might have your exact answer.
Steve
SteveCole
Honored Contributor
Steve
Thanks so much Steve.  That worked like a charm after I figured out I had to put it before I defined the popup.
