Identify Task no longer works on a previously functional map
2048
11-15-2012 05:55 AM
BrettGreenfield__DNR_
A couple of months ago my organization launched a map I put together, which can be found here: http://gisapps.dnr.state.md.us/Aquaculture/index.html
The map worked fine at the time of launch, and I didn't think anything more of it until the other day when I went to check it out again, and Firebug immediately started kicking up errors (see attachment).  The map still appears to be entirely functional with one exception: users are supposed to be able to click a feature and get an info window to popup - this no longer works.  Instead, Firebug kicks out more of the same errors.
I tried commenting out the part of the code that has the identify task and I'm still getting those errors when the map loads.  I also tried commenting other functionality one at a time and the errors persist.  I'm really not a programmer, so these errors are gibberish to me.  Would anybody be able to take a look at the code and help me establish where the problem is?
ShreyasVakil
I check the application and found that the identify fails because the MapService on which you do identity does not exist or somebody has removed or stopped the service.
See the following screenshot of the MapService on which you do identify:
[ATTACH=CONFIG]19341[/ATTACH][ATTACH=CONFIG]19342[/ATTACH]
If this application was working before, then I am sure by making the map service available the applicaiton should work fine.
This particular map service does not exist or is inaccessible:
http://mdewin25.mde.state.md.us/ArcGIS/rest/services/Shellfish_Closure_Areas/MapServer/
-Shreyas
ShreyasVakil
-Shreyas
Thank you so much!  Such a simple problem but I was having a real hard time pinpointing the source.  Thank you again.
