Message "Creating legend..."  and no legend is shown
916
11-15-2012 09:23 AM
JoseSanchez
Hi all
I am running the sample
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/layout_MapCont...
and pointing to a local ArcGIS Map Service running a map that has more than 20 layers.
The web page shows the message ""Creating legend...", but I left it run for several minutes and there isn't any legend.
Any suggestions?
thanks
MattO_Hara
Are you getting any error messages in the console?
If you go to the layers you are loading do they have a Legend section on the rest services like on the layers in example?
If your local arcserver is publically accessible it might help if you made a little example of your issue in jsfiddle.
