Identify Task Delay on Joined Layer Within Map Service
1016
02-09-2011 11:42 AM
ScottDavis
I have a map service that has a layer within it that is joined to an outside (non-sde) SQL Server database. On our development server it works fine. But on one of our production servers when I try to run an IdentifyTask against it I get a 30 second delay. I've had our network guy do a trace on the process and he can see the request from my web app hit our server immediately, but then there is a 30 second delay (exactly the same time consistently) before our server makes the request to the joined SQL server and then returns the data back to my web app. Just wondering if anyone else has run into the same problem.
MatthewLawton
Hi Scott, I have run into similar delays as you describe. I have published MXDs on our live server that have table joins or spatial views to non-spatial data in SQL Server and there is an inherent slowness to querying this data. I have even tried to build JSON queries to these services via REST, hoping that removing the spatial component would increase performance, but they are still slow. I came to the following conclusions:
1. ArcGIS Server must create a lot of database overhead when it performs queries.
2. In my situation, the live server is querying through a firewall, so there may be some sort of port delay or something like that.
The solution I came up with was to install a MySQL database locally on my ArcGIS Server web server and bulkload data that I wanted to join to my spatial layers. I built PHP queries that would pull data from the map service and use it to query the bulk loaded data in MySQL. Since the requests didn't have to go through a firewall or to any other server they were lightning quick. I even created an autocomplete address form that contains over 150,000 address records that is responsive to the keystroke. In the future I will not use ArcGIS Services to serve non-spatial data that can just as easily be loaded to the web server and be queried with PHP.
Hope this helps.
