Identifier for two map services
1535
04-03-2017 10:18 PM
VeenaHosur
HI,
I have two map services which both services contains some layers.I want identifier for both services.How can i do it.
http://xxx:6080/arcgis/rest/services/adc/yyyy/MapServer
http://xxx:6080/arcgis/rest/services/abc/zzz/MapServer
Tags (1)
RobertScheitlin__GISP
Veena,
   The IdentifyTask is what you are looking for then. Here is a sample on using the IdentifyTask (the sample one identifies one map service layer but can easily be modified to do more like you are wanting):
Display identify results in popup | ArcGIS API for JavaScript 3.20
KenBuja
MVP Esteemed Contributor
Here's an example of using multiple services in an IdentifyTask: https://community.esri.com/message/442805?commentID=442805#comment-382158
It's old and should be updated to modern syntax, but it give you an idea of how it's done.
