Icon displays underveath graphics
1426
07-30-2012 09:04 AM
KyleDixon
I have a map that draws polylines and displays icons. The icons are appearing underneath the graphics, how can I set the layering to always display the icons on top? Do I need to add another graphics layer?
JeffPace
As far as I am aware, graphics are always on top.  If you want icons on top of graphics you would have to render them IN the graphics layer.
KyleDixon
The icons are added to the graphics layer, but the icons are still displayed underneath.
JeffPace
my guess is that the graphicslayer is an array and is displaying based on order added.
I am not sure if you can "unshift" them or add them at a higher position/lower index.
derekswingley1
Each graphic has a getDojoShape method. Once you have the gfx object, you can call moveToFront or moveToBack.
