I need help removing paging from popup
5367
12-10-2015 07:57 AM
GideonGontor
I need help on how i can customize the windows popup so as to remove paging, i would like all the fields displayed on one page.
Tags (1)
RickeyFight
Gideon,
Can you post the code you have now?
GideonGontor
<!DOCTYPE html>
<html xmlns:mso="urn:schemas-microsoft-com:office:office" xmlns:msdt="uuid:C2F41010-65B3-11d1-A29F-00AA00C14882">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<!--The X-UA-Compatible meta tag is used to force IE to not display the page in compatability mode if set in the browser-->
<!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices-->
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Single Point Search</title>
<link rel="stylesheet" href="http://uat-gwb-v02.firescotland.local/arcgis_js_api/library/3.12/3.12/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://uat-gwb-v02.firescotland.local/arcgis_js_api/library/3.12/3.12/esri/css/esri.css">
<style>
html, body, #map {padding: 0; margin: 0; height: 100%; width: 100%; background-color:#D5EAFB;}
#measurementPane{
        width:240px;
      .claro .dijitTitlePaneTitle {
        background: #fff;
        font-weight:600;
        border: none;
        border-bottom:solid 1px #29201A;
        border-top:solid 1px #29201A;
      .claro .dijitTitlePaneTitleHover {
        background:#eee;
      .claro .dijitTitlePaneTitleActive {
        background:#808775;
      .claro .dijitTitlePaneContentOuter {
        border-right: none;
        border-bottom: none;
        border-left: none;
</style>
<script src="http://uat-gwb-v02.firescotland.local/arcgis_js_api/library/3.12/3.12/init.js"></script>
<script>
var map;
var measurementFlag = "0";
  require([
        "esri/InfoTemplate",
        "esri/map",
        "esri/geometry/Extent",
        "esri/dijit/Popup",
        "esri/layers/FeatureLayer",
        "esri/tasks/query",
        "dojo/dom-construct",
        "esri/layers/ArcGISTiledMapServiceLayer",
        "esri/geometry/Point",
        "esri/SpatialReference",
        "dojo/_base/Color",
        "esri/urlUtils",
        "dojo/dom",
        "esri/Color",
        "dojo/keys",
        "dojo/parser",
        "esri/config",
        "esri/sniff",
        "esri/SnappingManager",
        "esri/dijit/Measurement",
        "esri/renderers/SimpleRenderer",
        "esri/tasks/GeometryService",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/dijit/Scalebar",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
        "dijit/TitlePane",
        "dijit/form/CheckBox",
        "dojo/domReady!"
        function (
          InfoTemplate,
          Map,
          Extent,
          Popup,
          FeatureLayer,
          Query,
          domConstruct,
          Tiled,
          Point,
          SpatialReference,
          Color,
          urlUtils,
          dom, Color, keys, parser,
        esriConfig, has,  SnappingManager, Measurement,  SimpleRenderer, GeometryService, SimpleLineSymbol, SimpleFillSymbol
    // get x, y coordinates and zoom ;evel from URL querystring
      var q = urlUtils.urlToObject(window.location.href);
   var x = q.query.x;
   var y = q.query.y;
      var zoom = 13;
      parser.parse();
         //esriConfig.defaults.io.proxyUrl = "/proxy/";
        //esriConfig.defaults.io.alwaysUseProxy = false;
        //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications
        esriConfig.defaults.geometryService = new GeometryService("https://s-gwb-v02.firescotland.local/arcgis/rest/services/Utilities/Geometry/GeometryServer");
         var sfs = new SimpleFillSymbol(
          "solid",
          new SimpleLineSymbol("solid", new Color([195, 176, 23]), 2),
          null
      //Coordinates for testing - comment out before deploying
      // Define popup to replace InfoWindow to allow paged results
      var popup = Popup({
           },domConstruct.create("div"));
      //Create Infotemplate and define the title (Postal Address)
      //Call function (getTextContent) to display paged query results in content pane
      var addressTemplate = new InfoTemplate("Postal Address");
          addressTemplate.setContent(getTextContent);
          //Create map and use popup for Infowindow
          map = new Map("map", {
            infoWindow: popup,
      //After map is created, set centre point and zoom level
      var point = new esri.geometry.Point(x, y, new esri.SpatialReference({ wkid: 27700 }));
          map.centerAt(point);
          map.setZoom(zoom);
          //Once map is loaded call function (ShowLocation) to show marker symbol at x,y coordinates
          //The map must be loaded before symbol can be shown
          dojo.connect(map, "onLoad", function() {ShowLocation(x, y); });
      //Create basemap layer, this should be a Tiled layer (ArcGISTiledMapServiceLayer) if using FeatureLayers
      var baseLayer = new Tiled("https://s-gwb-v02.xxxxx.local/arcgis/rest/services/PROD/Cartographic/MapServer");
          map.addLayer(baseLayer);
      //Create gazeteer FeatureLayer and define attributes to shown in Popup
      //Address marker symbols are not shown in this layer
      var addressLayer = new FeatureLayer("http://arcgis.xxxxx.local/arcgis/rest/services/SFRSGazetteer/MapServer/0",
          mode: FeatureLayer.MODE_ONDEMAND,
          outFields: ["POSTAL_ADDRESS","UPRN"],
          infoTemplate: addressTemplate
          map.addLayer(addressLayer);
      //Create another gazeteer FeatureLayer to show marker symbols
      //var addressLayer2 = new FeatureLayer("http://arcgis.xxxxxx.local/arcgis/rest/services/SFRSGazetteer/MapServer/0")
      //    map.addLayer(addressLayer2);
         var parcelsLayer = new FeatureLayer("http://arcgis.xxxxxx.local/arcgis/rest/services/SFRSGazetteer/MapServer/0", {
          outFields: ["*"]
        parcelsLayer.setRenderer(new SimpleRenderer(sfs));
        map.addLayers([parcelsLayer]);
         //dojo.keys.copyKey maps to CTRL on windows and Cmd on Mac., but has wrong code for Chrome on Mac
        var snapManager = map.enableSnapping({
          snapKey: has("mac") ? keys.META : keys.CTRL
        var layerInfos = [{
          layer: parcelsLayer
        snapManager.setLayerInfos(layerInfos);
var measurement = new Measurement({
          map: map
        }, dom.byId("measurementDiv"));
        measurement.startup();
  measurement.hideTool("location");
  measurement.on("measure", function(evt){
  measurementFlag = "1";
  measurement.on("measure-start", function(evt){
  measurement.on("tool-change", function(evt){
  measurement.on("unit-change", function(evt){
  measurement.on("measure-end", function(evt){
          //Query to return mutiple paged results to Popup
          map.on("click", function (event) {
      var query = new Query();
          query.geometry = pointToExtent(map, event.mapPoint, 10);
      var deferred = addressLayer.selectFeatures(query);
          query.orderByFields = ["POSTAL_ADDRESS ASC"];
          //FeatureLayer.SELECTION_NEW);
          map.infoWindow.setFeatures([deferred]);
   if( measurementFlag == "0" )
  map.infoWindow.show(event.mapPoint);
//Extent for query
function pointToExtent (map, point, toleranceInPixel) {
        var pixelWidth = map.extent.getWidth() / map.width;
        var toleranceInMapCoords = toleranceInPixel * pixelWidth;
            return new Extent(point.x - toleranceInMapCoords,
                              point.y - toleranceInMapCoords,
                              point.x + toleranceInMapCoords,
                              point.y + toleranceInMapCoords,
                              map.spatialReference);
//Function to display and format query results in Popup content pane
function getTextContent(graphic)
        var address;
        var attributes = graphic.attributes;
  document.getElementById("hidUPRN").value= attributes.UPRN;
            address = (attributes.POSTAL_ADDRESS);
           address += "<br /><br /> <span style='color:blue;'> Select UPRN: </span>";
           address += "<a href='javascript:clickclose();' style='color:blue;text-decoration: underline;'>"+(attributes.UPRN)+"</a>";
            return address;
//Function to display marker symbol at address searched for
function ShowLocation(x, y)
        var point = new esri.geometry.Point(x, y, new esri.SpatialReference({wkid:4326}));
        var markerSymbol = new esri.symbol.SimpleMarkerSymbol();
            markerSymbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE);
            markerSymbol.setSize(16);
            markerSymbol.setColor(new dojo.Color([255,0,0,0.5]));
        var graphic = new esri.Graphic(point, markerSymbol);
            map.graphics.add(graphic);
function clickclose()
var returnValue = [];
returnValue[0] = document.getElementById("hidUPRN").value;
window.frameElement.commonModalDialogClose(1,returnValue);
</script>
<!--[if gte mso 9]><xml>
<mso:CustomDocumentProperties>
<mso:PublishingContactPicture msdt:dt="string"></mso:PublishingContactPicture><mso:PublishingRollupImage msdt:dt="string"></mso:PublishingRollupImage><mso:Audience msdt:dt="string"></mso:Audience><mso:PublishingContactName msdt:dt="string"></mso:PublishingContactName><mso:Comments msdt:dt="string"></mso:Comments><mso:PublishingContactEmail msdt:dt="string"></mso:PublishingContactEmail><mso:ContentTypeId msdt:dt="string">0x010100C568DB52D9D0A14D9B2FDCC96666E9F2007948130EC3DB064584E219954237AF3900F4701CD528482D47B8A53FE6E7A4D72B</mso:ContentTypeId><mso:ContentType msdt:dt="string">Page</mso:ContentType></mso:CustomDocumentProperties></xml><![endif]-->
</xml><![endif]-->
</xml><![endif]-->
</xml><![endif]-->
</head>
<body class="claro">
   <input type='hidden' id='hidUPRN'></input>
    <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:false"
    style="width:100%; height:100%;">
      <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
        <div style="position:absolute; right:20px; top:10px; z-Index:999;">
          <div id="measurementPane" data-dojo-type="dijit/TitlePane" open="false" title="Measurement">
            <div id="measurementDiv"></div>
            <!-- <span style="font-size:smaller;padding:5px 5px;">Press <b>CTRL</b> to enable snapping.</span> -->
          </div>
        </div>
      </div>
    </div>
  </body>
</html>
RickeyFight
Gideon,
I guess I am still confused what is going on.
Are you trying to remove (1 or 3 ).
I have never seen a popup that has multiple pages
GideonGontor
Yes, i am trying to remove (1 of 3) and have all the information on one page
