HTML5
1102
06-01-2014 11:14 PM
Jeremiah_OlatundeGbolagun
Please I would like to know why HTML5 has not been applied with the ArcGIS API for JavaScript.
For example the below HTML code is not HTML5.
<!DOCTYPE html>
  <html>
    <head>
      <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
      <title></title>
    </head>
  </html>
I am expecting to see the new HTML5 structure. Although, I can see the "DOCTYPE html" which is the first statement of the HTML5. I am also expecting the "head" element to be "HEADER"
Can you please explain why it was not implemented here.
Best regards,
Jeremiah.
JeffPace
stolen from stack overflow
<header> is one of several new tags in HTML5 that are supposed to replace <div> for some specific situations. In particular, the "header" part of your page - whatever that is, usually the part that would be wrapped in <div class="header"> - in HTML5 you should use <header> instead.
header is not a replacement for head.
more info
http://diveintohtml5.info/semantics.html
