How to work with real 3D data in a SceneView?
3462
12-03-2015 03:13 AM
janjermei
I have an ESRI map service that exposes polylines. This map service has HasZ: true.
The z-value is relative to the sea level, not to the terrain.
When I add this map service to a map and display it in a SceneView, I have the impression that the geometries are draped on the basemap and that their true z-values are ignored.
The map service has Spatial Reference: 31370.
Is it possible to display true 3D geometries in the SceneView?
Tags (1)
KristianEkenes
Hi Jan,
Yes you can display 3D geometries in a SceneView. How are you setting up the layer? Are you using FeatureLayer? If so, you would need to set the returnZ and elevationInfo properties like this:
var lyr = new FeatureLayer({
  url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/VerticalLines/MapServer/0",
  returnZ: true,
  elevationInfo: {
    mode: "absoluteHeight"
KristianEkenes
Hi Jan,
  returnZ: true,
  elevationInfo: {
