How to use Intersect Service published by Geometry Services?
1444
03-19-2014 10:20 AM
SherrillBauer
Hi there,
I am working on a project which need to use ArcGIS Online Geometry Services. I found a link from ESRI's website and be told that this one cannot work well (http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer). Is there any other available Geometry Service can be used?
Any advices and suggestions are appreciated.
Sherrill
JakeSkinner
Esri Esteemed Contributor
Hi Sherrill,
Do you have ArcGIS Server?  If so, you will have your own geometry service that you can use.
SherrillBauer
Hi Jake,
Yes, my organization has ArcGIS Server. Would you tell me how to get the Geometry Service from ArcGIS Server side?
Thanks a lot for your reply.
Sherrill
JakeSkinner
You can access it using the REST URL.  To get the URL, you can go to Start > Programs > ArcGIS > ArcGIS for Server > Services Directory.  Click on 'Utilities' > 'Utilities Geometry'.  You should have a URL similar to:
'http://localhost:6080/arcgis/rest/services/Utilities/Geometry/GeometryServer'
