How to use interface types with new ES modules
3289
04-22-2021 12:09 PM
RussellMGreen
What is the recommended way to use interfaces when using ES modules (@arcgis/core)?
For example, I have an Angular application that I have loaded:
import GeoJSONLayer from '@arcgis/core/layers/GeoJSONLayer';
import Graphic from '@arcgis/core/Graphic';
How would I gain access to a type like MapViewProperties?
I've tried installing the @types/arcgis-js-api package in addition to @arcgis/core, but that seems like it would be overkill.
Example:
import ImageryLayer from '@arcgis/core/layers/ImageryLayer';
import Esri = __esri; // <--- used just for interfaces
const mapOptions: Esri.MapProperties = {...};
What's the recommended approach?
Thanks!
ReneRubalcava
Esri Frequent Contributor
The @arcgis/core package already comes with the typings, no need for extra installs. You can continue to use the __esri namespace or alias it in your own d.ts file like this to use it in a short esri namespace.
ReneRubalcava
JonathanBorgia
Running into the same problem. My angular app complies fine, but then breaks on loading using the
"import esri = __esri" method. @ReneRubalcava I would like to try your suggestion, but the link no longer works.
ReneRubalcava
The import alias should still work, but might break depending on the tsconfig.
With the latest TypeScript, it's recommended that you utilize type-only imports.
import type FeatureLayer from "@arcgis/core/layers/FeatureLayer";
export function doSomethingWithLayer(layer: FeatureLayer) {
  // super cool stuff
If you want to do something like a factory method, where you want to type the properties used for something, you can do something like this.
import FeatureLayer from "@arcgis/core/layers/FeatureLayer";
type LayerFactoryProps = InstanceType<typeof FeatureLayer>;
export function layerFactory(props: LayerFactoryProps) {
  // maybe add some defaults here
  // create layer
  const layer = new FeatureLayer(props);
  return layer;
Ideally, I would recommend against using the __esri namespace, unless you really need it for things like the Event types, or watch/reactiveUtil handlers. Other than that, you should avoid it.
