How to use @arcgis/map-components with ArcGIS Enterprise?
969
11-05-2025 02:11 PM
MapNat
I installed @ArcGIS/map-components.
I want to view a simple webmap.
import '@arcgis/map-components/components/arcgis-map';
export default function MapView() {
  return (
    <arcgis-map
      // portal-url='https://my-portal-url.com/portal'
      item-id='abc123c5f0314db9a487a9b46cb37eca'
      style={{ height: '400px' }}
    ></arcgis-map>
I get something like:
Failed to load web map
Failed to load portal item
https://www.arcgis.com/sharing/rest/content/items/abc123c5f0314db9a487a9b46cb37eca
Item does not exist or is inaccessible.
Fair enough, because my webmap is not on ArcGIS Online; I'm using ArcGIS Enterprise.
How can I indicate that my portal URL is https://my-portal-url.com/portal ?
I tried adding a portal-url property to arcgis-map (commented out above) but it didn't change anything.
I tried loading the portal URL with @ArcGIS/core esriConfig first and it didn't change anything.
import { useEffect } from 'react';
import esriConfig from '@arcgis/core/config';
  useEffect(() => {
    esriConfig.portalUrl = 'https://my-portal-url.com/portal';
  return (
    <div style={{ width: '100%', height: '400px' }}>
      <arcgis-map item-id='abc123c5f0314db9a487a9b46cb37eca' style={{ height: '400px' }}></arcgis-map>
    </div>
Seems very basic, maybe silly... what am I missing?
Thanks in advance for your help!
ReneRubalcava
Esri Frequent Contributor
Set the `esriConfig.portalUrl` outside the useEffect, probably at the top of the page. In apps, I usually set this in the main entry point file or maybe in the `globalThis.esriConfig` before the map components are used.
MapNat
Thanks, @ReneRubalcava !
JustinKirtz1
Just wanted to say thank you as this solved my problems for me as well. For those that want a visual fix, this is all that it took in the head of my index.html file
GIS Supervisor for Greenville Water
