How to Use ArcGIS Javascript API with IBM worklight - Proxy setting issue
4443
02-25-2015 01:33 AM
ShashankKatte
Trying to create a hybrid mobile application using IBM worklight and ArcGIS Kavascript APIs. We are trying to create a simple navigation app using ArcGIS.
While using navigation widget from ArcGIS we are facing problem with proxy setup. Is proxy setup mandatory?
The code is as follows
<script src="http://js.arcgis.com/3.12/"></script>
    <script>
      require([
        "esri/urlUtils", "esri/map", "esri/dijit/Directions",
        "dojo/parser",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function(
        urlUtils, Map, Directions,
        parser
        parser.parse();
        //all requests to route.arcgis.com will proxy to the proxyUrl defined in this object.
        urlUtils.addProxyRule({
          urlPrefix: "http://route.arcgis.com",
          proxyUrl: "http://192.168.4.109:10080/ProxyServer/proxy.js"
          urlPrefix: "http://traffic.arcgis.com",
  var url = urlUtils.arcgisUrl;
        url= url.replace("file:", "http:");
        urlUtils.arcgisUrl = url;
        var map = new Map("map", {
          basemap: "streets",
          center:[-98.56,39.82],
          zoom: 4
        var directions = new Directions({
          map: map
        },"dir");
        directions.startup();
    </script>
we get error message:
Route service description was not reached or recognized. Please check service URL and OR user credential
02-25 15:01:08.604: I/chromium(17307): [INFO:CONSOLE(192)] "RequestError: Unable to load file://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World?f=json status: 0", source: http://js.arcgis.com/3.12/init.js (192)
Need help to resolve this issue.
BjornSvensson
Esri Alum
First, I'm not familiar with IBM worklight....
As for the routing, no a proxy is not needed, but if you don't use it, the users of your application would be prompted to log in.
You can test/see this in action by deleting the "urlUtils.addProxyRule" from this sandbox sample  or or this sandbox sample.
