How to successfully change the ESRI logo in JSAPI applications?
2669
03-16-2016 09:13 AM
GeoffreyWest
I am writing an Esri JavaScript API application and would like to replace the Esri logo with my client's logo. I have found that using logo.med allows me to replace the logo, however, there are size dependencies in the API that I cannot change. I would like my logo size to be about 85px x 29px. Here's an example of the image that I am using which appears incorrectly at the bottom right of the map. This incorrect because the image shows up 4 times. I am using .logo-med to change the logo. How can I set the CSS so that I can use the image at any size that I prefer?
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Create web map from id</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.16/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
      background-color: #FFF;
      overflow: hidden;
      font-family: "Helvetica";
    #rightPane {
      background-color: #E8E8E8;
      border: solid 2px #B8B8B8;
      margin: 5px;
      width: 20%;
    #map {
      margin: 5px;
      padding: 0;
    .esriLegendServiceLabel {
      display: none;
    #search {
      display: block;
      position: absolute;
      z-index: 10px;
      top: 25px;
      right: 1025px;
  .logo-med {
  background-image: url('capture2.png') !important;
  </style>
RobertScheitlin__GISP
Geoffrey,
  Can I see how you are adjusting the css to apply your logo?
GeoffreyWest
.logo-med {
Results in:
On Wed, Mar 16, 2016 at 9:20 AM, Robert Scheitlin, GISP <geonet@esri.com>
Geoffrey,
  So you need to override the .logo-meds height and width as well then:
.map .logo-med {
  display: inline-block;
  vertical-align: bottom;
  width: 65px;
  height: 36px;
  z-index: 30;
  background-image: url("../images/map/logo-med.png");
  cursor: pointer;
  _background-image: none;
