How to style info windows with CSS in JavaScript API?
6214
6
08-24-2011 09:11 AM
johnywhy
Hi
Is it possible to style info windows with CSS in the JavaScript API?
Thanks!
StephenLead
Honored Contributor
Hi Johny,
It sure is. If you haven't already done so, download Firefox and Firebug (the developer plugin).
Open one of the sample maps, open an infoWindow, and use the HTML Inspector within Firebug to see which CSS classes are being used. For example:
.infowindow .window .top .right .sprite {
    margin-top: 0;
    position: absolute;
.claro .infowindow .sprite {
    background-image: url("../images/claro.infowindow.png");
    height: 1000px;
    width: 1000px;
.infowindow .window {
    color: #000000;
    font-family: verdana,sans-serif;
You'll find a whole host of classes which you can modify to style the infoWindows the way you want them. You can overwrite these classes by including them in your own CSS files / style declarations.
Steve
KellyHutchins
Esri Notable Contributor
Along with the great info Steve provided you might want to check out the 'Customize Info Window' conceptual doc in the help:
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp/intro_customize.htm
johnywhy
awesome!
but before i dig into this, can this work with the embed provided by the online map maker?
thanks!
BretWhiteley1
Kelly, this link is broken, could you please update it?
Thanks
KellyHutchins
derekswingley1
