how to store locally tile layer  and feature layer  in html5
2777
01-29-2013 07:40 PM
sheebaashraf
Hi
I am developing a mobile application in HTML5 and ArcGIS java script API(s).I want user to use this application in offline mode,for this I need to store tile layers,feature layers and table data,etc in the HMTL5 local storage.
Please suggest.Sample code is appreciated.
Thanks
JeffJacobson
This question has been asked in a few other threads on this forum, but no good answers have been provided as far as I know.
The problem is that HTML 5's local storage limits the amount of data you can store for a web site, and this limit is too small to store very many map tiles.
chaoukisoussi
I found this sample http://developers.arcgis.com/en/javascript/jssamples/exp_webstorage.html, but I found some problems to download and execute it.
The problem is that when the XMLHttpRequest request pass throw my PHP proxy, the encoder generates a corrupted base64 tiles.
And no more corrupted tiles when I display a Map service that not require a proxy.
there is my PHP proxy code :
<?php
   * USAGE
   * [1] http://<this-proxy-url>?<arcgis-service-url>
   * [2] http://<this-proxy-url>?<arcgis-service-url> (with POST body)
   * [3] http://<this-proxy-url>?<arcgis-service-url>?token=ABCDEFGH
   * note: [3] is used when fetching tiles from a secured service and the
   * JavaScript app sends the token instead of being set in this proxy
   * REQUIREMENTS
   *  - cURL extension for PHP must be installed and loaded. To load it,
   *    add the following lines to your php.ini file:
   *     extension_dir = "<your-php-install-location>/ext"
   *     extension = php_curl.dll
   *  - Turn OFF magic quotes for incoming GET/POST data: add/modify the
   *    following line to your php.ini file:
   *     magic_quotes_gpc = Off
   * <true> to only proxy to the sites listed in '$serverUrls'
   * <false> to proxy to any site (are you sure you want to do this?)
  $mustMatch = true;
   * ArcGIS Server services this proxy will forward requests to
   * 'url'      = location of the ArcGIS Server, either specific URL or stem
   * 'matchAll' = <true> to forward any request beginning with the URL
   *              <false> to forward only the request that exactly matches the url
   * 'token'    = token to include for secured service, if any, otherwise leave it
   *              empty
  $serverUrls = array(
    array( 'url' => 'http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/', 'matchAll' => true, 'token' => '' ),
    array( 'url' => 'http://sampleserver2.arcgisonline.com/ArcGIS/rest/services/', 'matchAll' => true, 'token' => '' ),
    array( 'url' => 'http://sampleserver1a.arcgisonline.com/arcgisoutput/',        'matchAll' => true, 'token' => '' ),
    array( 'url' => 'http://sampleserver1b.arcgisonline.com/arcgisoutput/',        'matchAll' => true, 'token' => '' ),
    array( 'url' => 'http://sampleserver1c.arcgisonline.com/arcgisoutput/',        'matchAll' => true, 'token' => '' ),
 array( 'url' => 'http://services.arcgisonline.com/ArcGIS/rest/services/',      'matchAll' => true, 'token' => '' ),
 array( 'url' => 'http://services1.arcgis.com/',      'matchAll' => true, 'token' => '' )
  function is_url_allowed($allowedServers, $url) {
    $isOk = false;
    $url = trim($url, "\/");
    for ($i = 0, $len = count($allowedServers); $i < $len; $i++) {
      $value = $allowedServers[$i];
      $allowedUrl = trim($value['url'], "\/");
      if ($value['matchAll']) {
        if (stripos($url, $allowedUrl) === 0) {
          $isOk = $i; // array index that matched
          break;
      else {
        if ((strcasecmp($url, $allowedUrl) == 0)) {
          break;
    return $isOk;
  // check if the curl extension is loaded
  if (!extension_loaded("curl")) {
    header('Status: 500', true, 500);
    echo 'cURL extension for PHP is not loaded! <br/> Add the following lines to your php.ini file: <br/> extension_dir = &quot;&lt;your-php-install-location&gt;/ext&quot; <br/> extension = php_curl.dll';
    return;
  $targetUrl = $_SERVER['QUERY_STRING'];
  if (!$targetUrl) {
    header('Status: 400', true, 400); // Bad Request
    echo 'Target URL is not specified! <br/> Usage: <br/> http://&lt;this-proxy-url&gt;?&lt;target-url&gt;';
    return;
  $parts = preg_split("/\?/", $targetUrl);
  $targetPath = $parts[0];
  // check if the request URL matches any of the allowed URLs
  if ($mustMatch) {
    $pos = is_url_allowed($serverUrls, $targetPath);
    if ($pos === false) {
      header('Status: 403', true, 403); // Forbidden
      echo 'Target URL is not allowed! <br/> Consult the documentation for this proxy to add the target URL to its Whitelist.';
      return;
  // add token (if any) to the url
  $token = $serverUrls[$pos]['token'];
  if ($token) {
    $targetUrl .= (stripos($targetUrl, "?") !== false ? '&' : '?').'token='.$token;
  // open the curl session
  $session = curl_init();
  // set the appropriate options for this request
  $options = array(
    CURLOPT_URL => $targetUrl,
    CURLOPT_HEADER => false,
    CURLOPT_HTTPHEADER => array(
      'Content-Type: ' . $_SERVER['CONTENT_TYPE'],
      'Referer: ' . $_SERVER['HTTP_REFERER']
    CURLOPT_RETURNTRANSFER => true,
    CURLOPT_FOLLOWLOCATION => true
  // put the POST data in the request body
  $postData = file_get_contents("php://input");
  if (strlen($postData) > 0) {
    $options[CURLOPT_POST] = true;
    $options[CURLOPT_POSTFIELDS] = $postData;
  curl_setopt_array($session, $options);
  // make the call
  $response = curl_exec($session);
  $code = curl_getinfo($session, CURLINFO_HTTP_CODE);
  $type = curl_getinfo($session, CURLINFO_CONTENT_TYPE);
  curl_close($session);
  // set the proper Content-Type
  header("Status: ".$code, true, $code);
  header("Content-Type: ".$type);
  echo $response;
JeremyHazel
Did you ever get an answer to this?  It seems that I'm having the same issue on my Mac with php proxy.  It seems to work fine on my windows box with asp proxy though.
Jeremy
