How to stop queryTask execution?
3786
13
11-21-2012 03:32 AM
YvanBérard
Hi all,
i've created my own identify tool with the queryTask, but i can't find a way to stop the execution of the queryTask.
Is there a way to stop the execution?
Thanks.
function identificationTool(action,qryUE,queryTaskUE) {  alert(action);  if(action =="go")  {   dojo.connect(map, "onClick", function(evt)    {    console.log("Identification: click");           //onClick event returns the evt point where the user clicked on the map.          //This is contains the mapPoint (esri.geometry.point) and the screenPoint (pixel xy where the user clicked).          //set query geometry = to evt.mapPoint Geometry          qryUE.geometry = evt.mapPoint;           //Execute task and call showResults on completion          queryTaskUE.execute(qryUE, showResults);             });  }  else  {   dojo.connect(map, "onClick", function(evt)    {                         // Here we should stop the execution of the queryTaskUE    map.infoWindow.hide();   });  } }
YvanBérard
YES!!!
Finally!
It's working like "ArcMap"!!
here is my code if somebody need it.
function init() {         ...          $(document).ready(function()   {   toolAction(map,qryUE,queryTaskUE);  }); }  function toolAction(map,qryUE,queryTaskUE) {        ...     $("#identify_spot").bind("click", function(event)    {     // If it's the same tool   if( getActiveTool() == "#identify_spot" )   {    setActiveTool();                         // Clear all the graphics, but not the infoTemplate and I don't know why.    map.graphics.clear();    dojo.disconnect(getDojoClick());   }   // If it's the not same tool   else   {    setActiveTool("#identify_spot");    setDojoClick(dojo.connect(map, "onClick", function(evt)       {      identificationTool(qryUE,queryTaskUE,evt);      console.log("identification click");     })    );   }  }); }  var thisTool; var dojoAction;  function setActiveTool(tool) {  if(tool != null)  {   thisTool = tool;   $(thisTool).addClass("active_tool");   }  else  {   $(thisTool).removeClass("active_tool");   thisTool = "";   }  console.log(thisTool+" class=active_tool")  }  function getActiveTool() {  return thisTool; }  function setDojoClick(action) {  if( action != null )  {   dojoAction = action;  }  else  {   dojoAction = "vide";  } }  function getDojoClick() {  console.log("kill");  return dojoAction; }
YvanBérard
I've tried it with your idea (queryDeferred) but it doesn't seem to work.
When i call the function cancelExecute() it seems that the object queryDeferred is empty...but it's not supposed to. The queryDeferred is a global var. So why is it still empty and not working?
 console.log("identification? "+action)
 if(action == true )
                 queryDeferred = queryTaskUE.execute(qryUE);
                 queryDeferred.then(showResults,showError);
 if(action == false)
  cancelExecute();
 console.log("identification queryDeferred("+queryDeferred+") to stop = "+queryDeferred.fired)
 if(queryDeferred && (queryDeferred.fired > 0))
  console.log("Identification: stop");
  queryDeferred.cancel();
__Rich_
It is either out of scope or uninitialised.
Looking at your code, it looks like there's a path through identificationTool where cancelExecute could be called before queryDeferred has been set.
Have you got the rest of the code available?
I've had a 5 minute play with this, here's a snippet:
var def = queryTask.execute(query,
    function (featureSet) {
        alert("FeatureSet returned");
    function (err) {
        alert("Error...but can't get at the message/reason that you expected to see, unfortunately.\n\ndef.canceled (sic) = " + def.canceled);
def.cancel("A reason for cancelling can be provided here",/*not strict*/false);
This won't cancel the server-side processing (if that's what you're hoping for) but it does cancel the client-side processing of any results...but not in the way that the Dojo people intended, it would seem.
YvanBérard
Yes here is the "caller" of identificationTool.
function toolOnClick(map,qryUE,queryTaskUE)
 // IDENTIFICATION
 $('#identify').click(function () {
  if(activeTool == "identify_spot")
   $('#identify_spot').removeClass("active_tool");
   activeTool = "";
   identificationTool(false,qryUE,queryTaskUE);
  else
   if(activeTool != "")
    $('#'+activeTool).removeClass("active_tool");
   $('#identify_spot').addClass("active_tool");
   console.log("Identification: start");
   identificationTool(true,qryUE,queryTaskUE);
   activeTool = "identify_spot";
The function toolOnClick() is called from $(document).ready(function()); in the init function of my code. So when a user click on the identification tool the process of identification is started.
I tried your snippet but it doesn't seem to work. It seems that the featureSet is not working and the err function is always called.
 if(action == true )
         //queryDeferred = queryTaskUE.execute(qryUE);
         var def = queryTaskUE.execute(qryUE,
           showResults(featureSet);
       function (err)
         //queryDeferred.then(showResults,showError);
What am I missing to make this "work"?
__Rich_
You'll notice that in the snippet I provided that I am always calling def.cancel() hence why the error handler function is always being invoked - it's expected behaviour.
May I suggest that you wrap most (nearly all!) of the identify logic into a widget/module and let it handle executing/cancelling tasks, then all your UI component needs to do is delegate to the widget/module - it will be easier to maintain state within a sensible scope with this approach.
YvanBérard
Yes I understand, but what I want to do is when I click on my identification button, the identification process is starting. But when the user click on the identification button again (to deactivate it --> when the var action == false ) I want the queryTask to be stopped/cancelled. That is where the dojo.deferrer.cancel is suppose to be working.
But it's not.
And I can't figure out how to make it stop. In other module (like navigation toolbar) there is a method that stop the action (navToolbar.deactivate()) and this is exactly what I want to do, but with the queryTask.
 * �? COMPLETER
 var def;
 if(action == true )
       function (err)
 else
  // HERE WE STOP THE EXECUTION
  //cancelExecute();
  // this is not working because "def" is undefined even if I created it at the begining of the function.
  //def.cancel("A reason for cancelling can be provided here",/*not strict*/false);
 * �? COMPLETER
YvanBérard
Yes I'll try this approach and I'll come back if it works or not. Thanks.
__Rich_
But it's not.
 * �? COMPLETER
 var def;
 if(action == true )
       function (err)
 else
  //cancelExecute();
 * �? COMPLETER
Of course def will be undefined as the function is effectively reentrant, the previous invocation (and any variables in it) is out of scope.
You invoke the function on the first click, on the second click you invoke the function again, completely separately ('fresh' if you like) from the first invocation, this is expected.
Make sense?
YvanBérard
Make sense?
Yes you are right.
Thank's to you and to Mr. Eric Gosselin from ESRI Canada Tech Support, you helped me alot.
Mr. Gosselin suggest me to use the method dojo.disconnect()  (http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp/inside_events.htm) and I had to modify my code so when I want to identify a new parcel, I need to click again on the identification button.
Here is my code to do so and this is working.
 // IDENTIFICATION
  var dojoClick=dojo.connect(map, "onClick", function(evt)
   identificationTool(qryUE,queryTaskUE,dojoClick,evt);
 * �? COMPLETER
function identificationTool(qryUE,queryTaskUE,dojoClick,evt)
   function (err)
  // kill the handler
  dojo.disconnect(dojoClick);
Again, thank's to you all!
