How to Specify Out Unit to Be in Decimal Degree in JS API
9457
34
11-29-2017 03:53 PM
BehrouzHosseini
I am using a Map service on ARcGIS Server 10.4.1 which is in this format
Spatial Reference: 102100  (3857)
Single Fused Map Cache: false
Initial Extent:
      XMin: -9819759.37726215
      YMin: 5128008.078704429
      XMax: -9809084.764440382
      YMax: 5132626.115644935
Full Extent:
      XMin: -9819004.6505
      YMin: 5125535.589900002
      XMax: -9809349.0802
      YMax: 5131992.668099999
Units: esriMeters
Now when I query the service it returns the data in Meter format which I can not display back them on the map as new graphics. Can you please let me know how I can change the service configuration or OutUnit in ArcGIS JavaScript API to be in Decimal Degree
RobertScheitlin__GISP
Bengi,
   Add this line of code somewhere after the map is created:
console.info(map.spatialReference.wkid);
BehrouzHosseini
I am getting error on this
Uncaught TypeError: Cannot read property 'wkid' of undefined
Bengi,
   Then you are putting it before the map is ready.
BehrouzHosseini
Ok the output is this:
102100
Bengi,
   The the data is returning in the correct WKID and you don't need to change it.
See if the changes I made to lines 7 and 18 help your issue.
 var edgesResultFeatures = result.edges;
 console.log(edgesResultFeatures);
 var edgeGraphics;
 for (var j = 0, jl = edgesResultFeatures.length; j < jl; j++) {
   var featureSet = edgesResultFeatures[j].features;
   for (var i = 0, il = featureSet.length; i < il; i++) {
     edgeGraphics = new esri.Graphic(featureSet[i].geometry)
     graphicsLayerTraceNetworkEdges.add(edgeGraphics);
 var junctionsResultFeatures = result.junctions;
 console.log(junctionsResultFeatures);
 var junctionsGraphics;
 for (var j = 0, jl = junctionsResultFeatures.length; j < jl; j++) {
   var featureSet = junctionsResultFeatures[j].features;
     junctionsGraphics = new esri.Graphic(featureSet[i].geometry);
     graphicsLayerTraceNetworkJunctions.add(junctionsGraphics);
BehrouzHosseini
same! nothing on the Map! but on console!
Bengi,
 Try adding line 7 below and share the console results with me.
 var edgeGraphics;
     console.log(featureSet[i]);
BehrouzHosseini
There you are:
Bengi,
  The value is already a graphic so you should try this:
 var edgeGraphics;
     //edgeGraphics = new esri.Graphic(featureSet.geometry)
     graphicsLayerTraceNetworkEdges.add(featureSet[i]);
     //junctionsGraphics = new esri.Graphic(featureSet.geometry);
     graphicsLayerTraceNetworkJunctions.add(featureSet[i]);
BehrouzHosseini
I am afraid but still not working!
