How to specify layer with layer-add-result event?
9272
11-06-2014 09:33 AM
SimonHodge
The ArcGIS JavaScript API Map object has the following two events (text taken from the API):
layer-add
Fires any time a layer is added to the map. Should be used in favor of onLayerAdd. (Added at v3.5)
layer-add-result
Fires after specified layer has been added to the map. Should be used in favor of onLayerAddResult. (Added at v3.5)
layer-add does exactly what it says: fires every time a layer is added.  However, layer-add-result says it will fire after specified layer has been added.  How do you specify the layer to trigger this event to fire?
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Simon,
Here is an example:
     var map;
      require([
        "esri/map", "esri/layers/FeatureLayer",
        "dojo/on", "dojo/domReady!"
      ], function(
        Map, FeatureLayer,
        on
        map = new Map("mapDiv", {
          basemap: "streets",
          center: [-81.792107, 26.150807],
          zoom: 8
        on(map, "layer-add-result", function(){
          console.log(featureLayer)
        var featureLayer = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/0",{
            mode: FeatureLayer.MODE_ONDEMAND,
            outFields: ["*"]
        map.addLayer(featureLayer);
JakeSkinner
Hi Simon,
Here is an example:
     var map;
      require([
      ], function(
        Map, FeatureLayer,
        on
          basemap: "streets",
          zoom: 8
            outFields: ["*"]
SimonHodge
Hi Jake,
Thanks for a quick answer.  However, I don't see how that differs to the layer-add event - it looks like it will be fired every time a layer is added but the API says it is fired when a specified layer is added.
Simon
SteveCole
Honored Contributor
Second result when searching for "layer-add-result" within the JS API Space-
https://community.esri.com/message/93134#93134
SimonHodge
Yeah, I came across that too after I'd asked the question, but thought I'd leave my question up in case things have changed since then.  It doesn't look like they have and so I think it's just a case that the notes in the API are just a bit ambiguous.
JakeSkinner
If it matters, I would mark Steve's answer as correct.  The link he sent answers your question more directly.
