How to show specific layers only in the LayerList
2108
04-24-2024 12:28 PM
ForrestLin
LayerList will show all layer from map.layers in the list.
We will add layers to map.layers programmatically and don't want to show all layer from map.layers in the list.
How to show specific layers in the list.
Tags (1)
2 Solutions
Egge-Jan_Pollé
LayerList | API Reference | ArcGIS Maps SDK for JavaScript 4.29 | ArcGIS Developers:
To hide layers in the map from the LayerList widget, you must set the listMode property on the desired layers to hide.
MatthewDriscoll
Either set the layers you don't want listMode to "hide" or if you have a service with a lot of layers, like a MapImageLayer use the sublayers.
Egge-Jan_Pollé
MatthewDriscoll
ForrestLin
@Egge-Jan_Pollé @MatthewDriscoll
Thank you!
Forrest
