How to show popup in ESRI map on mouse hover
2902
10-12-2021 04:39 AM
RishavPathak
I want to show popup in ESRI map on mouse hover. Currently I am using Arcgis Javascrip API 4.19.
Is it possible to implement such features without using dojo?
If yes then can someone guide me on how to do it?
Thanks
KenBuja
MVP Esteemed Contributor
woriginal1
I think this sample code is what you're looking for: https://developers.arcgis.com/javascript/latest/sample-code/view-hittest/
GavinRehkemper
That view hitTest sample from @woriginal1  is probably the best resource. Here is an additional sample that uses the "pointer-move" event along with hitTest and a debounce to create a popup on mouse hover: https://codepen.io/gavinr/pen/WNEwKEq?editors=0010
Shows how to do proper "show popup on hover" using debouncing so that there's no flickering/stuttering. Example without debouncing: https://codepen.io/...
