How to show esri shapefile on top of a map using arcgis javascript api
11724
13
03-24-2012 12:59 AM
SolidSmoke
Please advise me how to upload a esri shapefile and show it on top of a map using arcgis javascript api. I ve seen this doing using silverlight api and esrcontrib. Is ther anything like this available for esri javascript api.
derekswingley1
Upload your shapefile to ArcGIS.com, save your webmap and create your JS API map from the ArcGIS.com webmap that uses your shapefile.
SolidSmoke
My client wants a Geospatial web application in which they need a facility to upload their shape file and view the same on top of map. So uploading the shapefile in ArcGIS.com will not work in my case. So please advise me how I can create the same functionality of ArcGIS.com using ArcGIS api for javascript.
JeffPace
As far as I know this is not possible.  If it were, you would not need to purchase ArcGIS Server licenses.
JamesVillanueva
Take a look at this library: http://badassjs.com/post/845509816/r...ith-javascript
and the HTML5 CSV drag and drop example: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm
Combining the two together can provide you with the solution you need. Of course this assuming that you can use HTML5 in you're development.
The issues you'll find later: IE  - you're going to need a different solution as it doesn't support the file API, Safari will require a file input control as they don't support drag and drop, your going to be limited to newer browsers with html5 support, and your code will need to be written to support asynchronous file loading as you will need to wait for the dbf and shp files to both be loaded.
StephenLead
Honored Contributor
Along similar lines to James's approach, you could convert the shapefile to JSON then create a feature layer from the feature collection.
SwapnaGogineni1
Hi Solid Smoke,
Did you ever find a solution for adding shapefiles using javascript api??
-Swapna
HemingZhu
Hi Solid Smoke,
-Swapna
One approach i would give a try is to develop a GP tool where you could upload the shape file to a featurelayer on a map service.
JeffPace
There is no direct way.  You will have to either script or convert the data.
Charles__Jamie_Phillips
It can be done.  It would be easier as json/geojson/csv, but it is doable.  Here is a library that was written in js to do it:  https://github.com/RandomEtc/shapefile-js.
Basically, you are going to have to read it and make graphics from the data in the shapefile.  It may run a little slowly and will probably cause issues in IE if it is not fast enough since the javascript engine does not have the performance of the other browsers.  Hope this helps.
