How to set width and height of an image
2725
06-27-2016 12:53 PM
PavelVasilyev
I'm trying to add an image to the map using Javascript API 3.16. But I can't apply width and height to the image.
When I'm adding the image, style attribute of the image is set to width, height of map style. So the image is stretched.
Here is the piece of code I'm using:
    require(["esri/layers/MapImageLayer",
            "esri/layers/MapImage"],
            function(MapImageLayer, MapImage) {
                var newImage = MapImage({
                            'extent': self.map.extent.toJson(),
                            'href': url
                newImage.width = width;
                newImage.height = height;
                var imageLayer = new MapImageLayer({
                imageLayer.addImage(newImage);
                self.map.addLayer(imageLayer);
Tags (1)
DanPatterson_Retired
normally, if you set one, you let the other autoscale, ... at least in most arc* software
PanagiotisPapadopoulos
maybe you have to define the correct image extent for the selected image width and height
