How to set which wms layer is shown on top?
1161
03-19-2012 06:57 AM
ChadFanguy
I would like to set which wms layer that is shown on top. I assume I set it with the z-index, but how would I do this?
KenDoman
the JavaScript API provides methods to move the layers on the map. Here's an example, just replace the urls with something that works.
dojo.require("esri.map"); dojo.require("esri.layers.wms");  var map = new esri.Map("mapdiv");  // to initially set the layer order, create an array of layers var layerList = dojo.map(["base", "dog", "cat", "bird", "car"], function (urlEnding) { return new esri.layers.WMSLayer("http://wms-source/layer/" + urlEnding); });  map.addLayers(layerList); // map layer order: // ["base", "dog", "cat", "bird", "car"]  // now if you want to move a layer around, use map.reorderLayer var movingLayer = new esri.layers.WMSLayer("http://wms-source/layer/toMove"); map.addLayer(movingLayer); // map layer order: // ["base", "dog", "cat", "bird", "car", movingLayer]  map.reorderLayer(movingLayer, 2);  // second number is index of map layer where you want to move the layer. // index of 0 is base layer (bottom layer) // map layer order: // ["base", "dog", movingLayer, "cat", "bird", "car"]
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/map.htm#reorderLayer
KenDoman
