How to set extent of the map as per feature definition
5038
05-19-2016 04:10 AM
SatyanarayanaNarmala
I have a state layer in which counties exists. i have definied the layer by which the layer only showing the counties existing in a particular state as below. but how can make this defined state to be as a map extent.
var featureLayer1 = new FeatureLayer("XYZ",{
          mode: FeatureLayer.MODE_ONDEMAND,
          outFields: ["*"],
        //minScale : 800000,
        //maxScale : 0,
          infoTemplate: template
        featureLayer1.setDefinitionExpression("sde.sde.TS_Const.dname = '" + distname + "'");
FC_Basson
Once the featureLayer is loaded and the definition expression is defined, you can zoom to the graphics with:
map.setExtent(esri.graphicsExtent(featureLayer.graphics));
FC_Basson
FC_Basson
But this approach requires the featureLayer graphics to be visible in the current map extent.
FC_Basson
The best option would be to get the extent of the definition expression features with the featureLayer queryExtent function after load:
featureLayer.on('load', function(){
   var query = new esri.tasks.Query();
   query.where = "sde.sde.TS_Const.dname = '" + distname + "'";
   featureLayer.queryExtent(query,function(result){
      map.setExtent(result.extent);
ChrisSmith7
Honored Contributor
Please note, this does not work if your feature layer is hosted in ArcGIS Server, unless it is v10.3.1+:
Get the extent of features that satisfy the input query. The count of features that satisfy the input query is returned as well. This is valid only for hosted feature services on arcgis.com and for ArcGIS Server 10.3.1 and later. (Added at v3.9)
